Salta al contenuto principale
Acer Aspire One D250-1151 Battery Replacement
  1. Acer Aspire One D250-1151 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is unplugged, and turned off completely
    • Place the computer on a flat surface with the bottom facing you.
  2. Acer Aspire One D250-1151 Battery Replacement: passo 2, immagine 1 di 1
    • Place a finger on the small tab on the left with the lock and unlock symbols.
    • Slide this tab to the unlock position.
    • If done correctly, you should see an orange marker.
  3. Acer Aspire One D250-1151 Battery Replacement: passo 3, immagine 1 di 1
    • Place a finger on the tab in the upper right corner.
    • Slide this tab to the right and hold it in that position.
  4. Acer Aspire One D250-1151 Battery Replacement: passo 4, immagine 1 di 1
    • Place your finger on the three lines in the middle of the battery while holding the tab on the right.
  5. Acer Aspire One D250-1151 Battery Replacement: passo 5, immagine 1 di 1
    • Push forward on the battery lines while holding the tab on the right.
Conclusione
Evan Edmunds
Membro da: 10/31/16
237 Reputazione
2 Guide realizzate
Baylor, Team 5-11, Williams Fall 2016 Membro di Baylor, Team 5-11, Williams Fall 2016
BU-WILLIAMS-F16S5G11
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,344
