Salta al contenuto principale
Acer Aspire One D225-1625 Wireless Card Replacement
Cosa ti serve
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: passo 1, immagine 1 di 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: passo 1, immagine 2 di 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: passo 1, immagine 3 di 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 2 Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: passo 3, immagine 2 di 2
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: passo 4, immagine 1 di 2 Acer Aspire One D225-1625 Wireless Card Replacement: passo 4, immagine 2 di 2
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: passo 5, immagine 1 di 2 Acer Aspire One D225-1625 Wireless Card Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
Conclusione
Un commento
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 27
Tutti i Tempi: 417
