Salta al contenuto principale
Acer Aspire One D150 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire One D150 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip computer over, being sure the device is unplugged, powered off, and battery removed.
    • Then, locate two screws for hard drive.
  2. Acer Aspire One D150 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Next, loosen both screws and remove plastic door.
  3. Acer Aspire One D150 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Grasp translucent plastic tab and pull to the side so hard drive comes free of SATA connectors
  4. Acer Aspire One D150 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove hard drive from computer and loosen 4 screws that hold it into it's metal housing.
    • Buy yourself a larger and/or faster 2.5in hard drive.
    • Redo the steps in reverse to reassemble the hard drive.
Conclusione
Altre 8 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 18,429
