Salta al contenuto principale
Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement
Cosa ti serve
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Gently remove the back lid.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: passo 2, immagine 1 di 1
    • Once the panel is removed, you will see two speakers that is attached to the motherboard by a black cord.
    • Pull the cord gently to remove, you may have to wiggle the cord if it does not come out smoothly.
    • Repeat the process to remove the other cord.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: passo 3, immagine 1 di 1
    • Pull upwards to remove the speaker.
    • Repeat the process to remove the second speaker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 168
