Salta al contenuto principale
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 2, immagine 1 di 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 2, immagine 2 di 2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 3, immagine 1 di 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 6, immagine 1 di 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 6, immagine 2 di 2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 8, immagine 1 di 1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: passo 9, immagine 1 di 1
    • Gently pull the motherboard away from the small square chip to its left.
Conclusione
Un commento
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,205
