Introduzione
This guide is simple to follow. The Speaker can easily be removed and installed within minutes.
Cosa ti serve
Flip device over so that the battery is farthest from you.
Identify the switch on the upper left corner and push it left to be in "unlocked" position.
Close and flip the device over so you can have a good view of all the screws.
Locate and remove the three 3.9mm screws where the battery was removed from.
Locate and and remove the two 5.8mm screws located underneath the bumpers.
Locate and remove the three 5.8mm remaining screws at the top of the device.
Locate and remove the four 3.9mm screws on the right side of your device.
Locate and remove the 3.9mm screws holding the speakers in place.
Gently lift up the speakers from the frame.
