Salta al contenuto principale
Acer Aspire One A150-1570 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: passo 2, immagine 1 di 2 Acer Aspire One A150-1570 Keyboard Replacement: passo 2, immagine 2 di 2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: passo 3, immagine 1 di 2 Acer Aspire One A150-1570 Keyboard Replacement: passo 3, immagine 2 di 2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: passo 4, immagine 1 di 3 Acer Aspire One A150-1570 Keyboard Replacement: passo 4, immagine 2 di 3 Acer Aspire One A150-1570 Keyboard Replacement: passo 4, immagine 3 di 3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: passo 5, immagine 1 di 3 Acer Aspire One A150-1570 Keyboard Replacement: passo 5, immagine 2 di 3 Acer Aspire One A150-1570 Keyboard Replacement: passo 5, immagine 3 di 3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
Conclusione
Altre 2 persone hanno completato questa guida.
Blue
Membro da: 10/10/16
124 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 413
