Salta al contenuto principale
Acer Aspire One 725-0845 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire One 725-0845 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Keyboard Replacement: passo 2, immagine 1 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 2, immagine 2 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 2, immagine 3 di 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Keyboard Replacement, Back Plate: passo 3, immagine 1 di 3 Acer Aspire One 725-0845 Keyboard Replacement, Back Plate: passo 3, immagine 2 di 3 Acer Aspire One 725-0845 Keyboard Replacement, Back Plate: passo 3, immagine 3 di 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Keyboard Replacement, Hard Drive: passo 4, immagine 1 di 2 Acer Aspire One 725-0845 Keyboard Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Keyboard Replacement, Inner Frame: passo 6, immagine 1 di 3 Acer Aspire One 725-0845 Keyboard Replacement, Inner Frame: passo 6, immagine 2 di 3 Acer Aspire One 725-0845 Keyboard Replacement, Inner Frame: passo 6, immagine 3 di 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Keyboard Replacement: passo 7, immagine 1 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 7, immagine 2 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 7, immagine 3 di 3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Keyboard Replacement: passo 8, immagine 1 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 8, immagine 2 di 3 Acer Aspire One 725-0845 Keyboard Replacement: passo 8, immagine 3 di 3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Keyboard Replacement, Keyboard: passo 9, immagine 1 di 2 Acer Aspire One 725-0845 Keyboard Replacement, Keyboard: passo 9, immagine 2 di 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the 17 screws (3.0 mm) from the back of the keyboard.
  10. Acer Aspire One 725-0845 Keyboard Replacement: passo 10, immagine 1 di 2 Acer Aspire One 725-0845 Keyboard Replacement: passo 10, immagine 2 di 2
    • Remove the keyboard by lifting up and away from the cover/palm rest. Be careful with the keyboard connection during this step.
    • To replace an individual key, remove the key from the keyboard using a plastic opening tool.
Conclusione
Altre 3 persone hanno completato questa guida.
Jose Souto
Membro da: 02/15/17
337 Reputazione
3 Guide realizzate
USF Tampa, Team 8-3, Eyestone Spring 2017 Membro di USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 850
