Salta al contenuto principale
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: passo 2, immagine 1 di 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: passo 4, immagine 1 di 2 Acer Aspire One 722 Battery Replacement: passo 4, immagine 2 di 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: passo 5, immagine 1 di 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
    Thanks-gr8 guide
    hotcatz - Replica
    Thanks for the easy to follow instructions and for the great pictures. That made everything easy.
    Siegfried Harrison Ph.D. - Replica
Conclusione
Altre 12 persone hanno completato questa guida.
4 Commenti
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - Replica
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - Replica
Thank you, you are a hero of 2021.
Athirah siagian - Replica
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 58
Tutti i Tempi: 12,314
