Salta al contenuto principale
Acer Aspire One 532h-2806 Screen Replacement
Cosa ti serve
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: passo 1, immagine 1 di 2 Acer Aspire One 532h-2806 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: passo 2, immagine 1 di 2 Acer Aspire One 532h-2806 Screen Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: passo 3, immagine 1 di 2 Acer Aspire One 532h-2806 Screen Replacement: passo 3, immagine 2 di 2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: passo 4, immagine 1 di 3 Acer Aspire One 532h-2806 Screen Replacement: passo 4, immagine 2 di 3 Acer Aspire One 532h-2806 Screen Replacement: passo 4, immagine 3 di 3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: passo 5, immagine 1 di 1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: passo 6, immagine 1 di 1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: passo 7, immagine 1 di 2 Acer Aspire One 532h-2806 Screen Replacement: passo 7, immagine 2 di 2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: passo 8, immagine 1 di 3 Acer Aspire One 532h-2806 Screen Replacement: passo 8, immagine 2 di 3 Acer Aspire One 532h-2806 Screen Replacement: passo 8, immagine 3 di 3
    • Remove the screen.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 299
