Salta al contenuto principale
Acer Aspire One 532h-2527 RAM Replacement
Cosa ti serve
  1. Acer Aspire One 532h-2527 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 RAM Replacement: passo 2, immagine 1 di 1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 RAM Replacement: passo 3, immagine 1 di 1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 RAM Replacement: passo 4, immagine 1 di 3 Acer Aspire One 532h-2527 RAM Replacement: passo 4, immagine 2 di 3 Acer Aspire One 532h-2527 RAM Replacement: passo 4, immagine 3 di 3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Use the #0 Phillips Screw bit with the Screwdriver to remove the single 6mm Phillips screw from the small back plate.
  6. Acer Aspire One 532h-2527 RAM Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool on the recessed notch at the bottom of the small plate to gently lift the plate up
  7. Acer Aspire One 532h-2527 RAM Replacement: passo 7, immagine 1 di 2 Acer Aspire One 532h-2527 RAM Replacement: passo 7, immagine 2 di 2
    • Once the plate becomes unhinged, gently rotate the plate to take it of of the device.
  8. Acer Aspire One 532h-2527 RAM Replacement: passo 8, immagine 1 di 2 Acer Aspire One 532h-2527 RAM Replacement: passo 8, immagine 2 di 2
    • Using two fingers, gently spread the latches on the sides of the RAM card until the RAM card props up.
  9. Acer Aspire One 532h-2527 RAM Replacement: passo 9, immagine 1 di 2 Acer Aspire One 532h-2527 RAM Replacement: passo 9, immagine 2 di 2
    • Once the RAM card is propped up, carefully pull it out of its port.
Conclusione
Jair Burgos
Membro da: 09/15/16
425 Reputazione
3 Guide realizzate
USF Tampa, Team 11-6, Blackwell Fall 2016 Membro di USF Tampa, Team 11-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 607
