Introduzione
This guide will show how to remove the HDD from your netbook. The removal of the hard drive will allow you to replace it or upgrade it to a Solid State Drive (SSD).
Cosa ti serve
Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
Altre 4 persone hanno completato questa guida.
