Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
In this guide, you will be replacing the power jack, which is independently secured without the use of any internal screws.
Parti
Nessuna parte specificata.
  1. Use a Phillips #1 screwdriver to remove all eighteen 2.12 mm screws from the back plate of your Acer Aspire.
    • Use a Phillips #1 screwdriver to remove all eighteen 2.12 mm screws from the back plate of your Acer Aspire.
  2. Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate. Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate.
    • Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate.
  3. Unplug the power jack from the receptor port on the motherboard, highlighted in red. Remove the power jack from designated area on the side of the computer, highlighted in orange.
    • Unplug the power jack from the receptor port on the motherboard, highlighted in red.
    • Remove the power jack from designated area on the side of the computer, highlighted in orange.
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 138
