Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will show how to remove and replace the hard drive of an Acer 583P-9688.
  1. Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be. To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 634
