Salta al contenuto principale
Acer Aspire ES1-711-P1UV Battery Replacement
Cosa ti serve
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: passo 3, immagine 1 di 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Excellent instructions, Thxz.
jmarquez_cruz - Replica
Wuen i reassemble my laptop doesnt power on…
mk Bane - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 25
Tutti i Tempi: 4,086
