Salta al contenuto principale
Acer Aspire ES1-512-C80E Disk Drive Replacement
Cosa ti serve
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 2, immagine 1 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 2, immagine 2 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 2, immagine 3 di 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: passo 3, immagine 1 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: passo 3, immagine 2 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: passo 3, immagine 3 di 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 4, immagine 1 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 4, immagine 2 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 4, immagine 3 di 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 5, immagine 1 di 2 Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 5, immagine 2 di 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: passo 6, immagine 1 di 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: passo 7, immagine 1 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: passo 7, immagine 2 di 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: passo 7, immagine 3 di 3
    • Push the disk drive out of the side slot.
Conclusione
To reassemble your device, follow the steps in reverse order.
Peter Bulman
Membro da: 10/31/19
231 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 458
