Salta al contenuto principale
Acer Aspire E5-721-64T8 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire E5-721-64T8 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the two 6mm J0 screws located in the right and left side of the battery.
    • Make sure to unplug of disconnect the power cable before removing the battery.
  2. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 2, immagine 1 di 2 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the connector from the motherboard.
  3. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, immagine 1 di 3 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, immagine 2 di 3 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the two 6mm Phillips J0 screws located in the right and left side of heatsink mounts.
    • Remove the four 6mm Phillips J0 screws located on the heatsink power mount.
    • Lift and remove heatsink from motherboard completely.
  4. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 4, immagine 1 di 2 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove wi-fi card by pulling from socket.
  5. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove screen connector by pulling it upwards.
  6. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove speaker connector from the motherboard by pulling on the tab.
  7. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, immagine 1 di 3 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, immagine 2 di 3 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the four blue tabbed ribbon connectors to the motherboard by lifting white clamps and pulling out connector.
  8. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 8, immagine 1 di 2 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove black ribbon connector by lifting white clamp and pulling connector out.
  9. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 9, immagine 1 di 2 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 9, immagine 2 di 2
    • Finally lift motherboard from narrow side and jiggle it out so all ports going through the laptop case on the left slide out.
Conclusione
Ed Herrera
Membro da: 01/25/18
390 Reputazione
3 Guide realizzate
USF Tampa, Team S7-G3, Passmore Spring 2018 Membro di USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 191
