Salta al contenuto principale
Introduzione
All batteries wear out in time and lead to poor battery life. This guide will show you how to replace your battery on the Acer Aspire E5-573G
  1. Unscrew the single (5mm) Philips head screw holding the drive in place.
    • Unscrew the single (5mm) Philips head screw holding the drive in place.
  2. Pull out the optical drive.
    • Pull out the optical drive.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Unscrew all 17 (5mm) Philips head screws from the bottom. Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
    • Unscrew all 17 (5mm) Philips head screws from the bottom.
    • Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
  5. Run a pick around the edge of the laptop (between the two parts) to open it. Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
    • Run a pick around the edge of the laptop (between the two parts) to open it.
    • Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
  6. Unplug the battery and remove it.
    • Unplug the battery and remove it.
Conclusione
Altre 4 persone hanno completato questa guida.
Alex Bahm
Membro da: 18/01/2018
1.424 Reputazione
6 Guide realizzate
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro di Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
3 Membri
13 Guide realizzate
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Replica
Here are some links I found with a quick search of your model. These should work, but you should make sure they do before you order.
This link specifically mentions your model and is in the US
https://www.walmart.com/ip/BattPit-Lapto...
These links are from Canada and appear to be the same battery
http://www.battdepot.com/ca/model/notebo...
http://www.laptopcharge.ca/category/note...
https://www.bestbuy.ca/en-ca/product/lap...
Alex Bahm -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 53
Ultimi 30 Giorni: 309
Tutti i Tempi: 2,647
