Salta al contenuto principale
Acer Aspire E5-571P-55TL Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire E5-571P-55TL Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 2, immagine 1 di 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 3, immagine 1 di 2 Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 3, immagine 2 di 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: passo 4, immagine 1 di 2 Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 5, immagine 1 di 3 Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 5, immagine 2 di 3 Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 5, immagine 3 di 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  7. Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 7, immagine 1 di 2 Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 7, immagine 2 di 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  8. Acer Aspire E5-571P-55TL Hard Drive Replacement: passo 8, immagine 1 di 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 153
