Salta al contenuto principale
Acer Aspire E5-571 WiFi Replacement
Cosa ti serve
  1. Acer Aspire E5-571 WiFi Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: passo 2, immagine 1 di 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 WiFi Replacement: passo 3, immagine 1 di 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: passo 5, immagine 1 di 3 Acer Aspire E5-571 WiFi Replacement: passo 5, immagine 2 di 3 Acer Aspire E5-571 WiFi Replacement: passo 5, immagine 3 di 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 WiFi Replacement: passo 6, immagine 1 di 2 Acer Aspire E5-571 WiFi Replacement: passo 6, immagine 2 di 2
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: passo 7, immagine 1 di 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: passo 8, immagine 1 di 2 Acer Aspire E5-571 WiFi Replacement: passo 8, immagine 2 di 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: passo 9, immagine 1 di 3 Acer Aspire E5-571 WiFi Replacement: passo 9, immagine 2 di 3 Acer Aspire E5-571 WiFi Replacement: passo 9, immagine 3 di 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
Conclusione
Altre 9 persone hanno completato questa guida.
daniel sawyer
Membro da: 08/23/15
2.566 Reputazione
5 Guide realizzate
USF Tampa, Team 4-2, Meier Fall 2015 Membro di USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Membri
5 Guide realizzate
7 Commenti
Very well done - thank you!
glgsolutions - Replica
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - Replica
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - Replica
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 7,600
