Salta al contenuto principale
Acer Aspire E3-111-C0WA Wireless Card Replacement
Cosa ti serve
  1. Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, immagine 1 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, immagine 2 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, immagine 3 di 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 3, immagine 1 di 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, immagine 1 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, immagine 2 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, immagine 3 di 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 5, immagine 1 di 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 5, immagine 2 di 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 6, immagine 1 di 2 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 6, immagine 2 di 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: passo 7, immagine 1 di 2 Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: passo 7, immagine 2 di 2
    • Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
  8. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, immagine 1 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, immagine 2 di 3 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, immagine 3 di 3
    • Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
    • Pull the wireless card horizontally away from the motherboard to remove it from the connector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 358
