Salta al contenuto principale
Acer Aspire E1-531-2438 Wifi Card Replacement
Cosa ti serve
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 2, immagine 1 di 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: passo 3, immagine 1 di 2 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: passo 3, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, immagine 1 di 3 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, immagine 2 di 3 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, immagine 3 di 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 5, immagine 1 di 1
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 6, immagine 1 di 2 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 963
