Salta al contenuto principale
Acer Aspire E1-531-2438 RAM Replacement
Cosa ti serve
  1. Acer Aspire E1-531-2438 RAM Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire E1-531-2438 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 RAM Replacement: passo 2, immagine 1 di 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 RAM Replacement, RAM: passo 3, immagine 1 di 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: passo 3, immagine 2 di 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  4. Acer Aspire E1-531-2438 RAM Replacement: passo 4, immagine 1 di 3 Acer Aspire E1-531-2438 RAM Replacement: passo 4, immagine 2 di 3 Acer Aspire E1-531-2438 RAM Replacement: passo 4, immagine 3 di 3
    • Gently press outward on the two tabs that lock the RAM module in place.
    • Once the RAM module releases and flips up, gently pull the RAM module directly out of its socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 587
