Salta al contenuto principale
Acer Aspire E1-510-2500 RAM Card Replacement
Cosa ti serve
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: passo 2, immagine 1 di 2 Acer Aspire E1-510-2500 RAM Card Replacement: passo 2, immagine 2 di 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: passo 3, immagine 1 di 2 Acer Aspire E1-510-2500 RAM Card Replacement: passo 3, immagine 2 di 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: passo 4, immagine 1 di 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: passo 4, immagine 2 di 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: passo 5, immagine 1 di 2 Acer Aspire E1-510-2500 RAM Card Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: passo 6, immagine 1 di 3 Acer Aspire E1-510-2500 RAM Card Replacement: passo 6, immagine 2 di 3 Acer Aspire E1-510-2500 RAM Card Replacement: passo 6, immagine 3 di 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: passo 7, immagine 1 di 2 Acer Aspire E1-510-2500 RAM Card Replacement: passo 7, immagine 2 di 2
    • Carefully remove the RAM card from its home.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 567
