Salta al contenuto principale
Acer Aspire E 11 RAM Replacement
Cosa ti serve
  1. Acer Aspire E 11 RAM Replacement, Lower Case: passo 1, immagine 1 di 2 Acer Aspire E 11 RAM Replacement, Lower Case: passo 1, immagine 2 di 2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 RAM Replacement: passo 2, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 2, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 2, immagine 3 di 3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 RAM Replacement, Battery: passo 3, immagine 1 di 2 Acer Aspire E 11 RAM Replacement, Battery: passo 3, immagine 2 di 2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 RAM Replacement: passo 4, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 4, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 4, immagine 3 di 3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 RAM Replacement: passo 5, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 5, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 5, immagine 3 di 3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 RAM Replacement: passo 6, immagine 1 di 1
    • Carefully remove the battery by lifting it out of the casing.
  7. Acer Aspire E 11 RAM Replacement, Motherboard: passo 7, immagine 1 di 3 Acer Aspire E 11 RAM Replacement, Motherboard: passo 7, immagine 2 di 3 Acer Aspire E 11 RAM Replacement, Motherboard: passo 7, immagine 3 di 3
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 RAM Replacement: passo 8, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 8, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 8, immagine 3 di 3
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 RAM Replacement: passo 9, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 9, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 9, immagine 3 di 3
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 RAM Replacement: passo 10, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 10, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 10, immagine 3 di 3
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 RAM Replacement: passo 11, immagine 1 di 2 Acer Aspire E 11 RAM Replacement: passo 11, immagine 2 di 2
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 RAM Replacement: passo 12, immagine 1 di 3 Acer Aspire E 11 RAM Replacement: passo 12, immagine 2 di 3 Acer Aspire E 11 RAM Replacement: passo 12, immagine 3 di 3
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 RAM Replacement: passo 13, immagine 1 di 1
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 RAM Replacement: passo 14, immagine 1 di 1
    • The motherboard can now be lifted out from the laptop casing.
  15. Acer Aspire E 11 RAM Replacement, RAM: passo 15, immagine 1 di 3 Acer Aspire E 11 RAM Replacement, RAM: passo 15, immagine 2 di 3 Acer Aspire E 11 RAM Replacement, RAM: passo 15, immagine 3 di 3
    • Once the motherboard has been removed from the device, flip the motherboard over to reveal the RAM chip.
    • Using your thumbs slide RAM card down and out of its slot.
Conclusione
Altre 2 persone hanno completato questa guida.
Robert Cobaich
Membro da: 09/03/15
2.073 Reputazione
3 Guide realizzate
USF Tampa, Team 16-1, Blackwell Winter 2016 Membro di USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 3,055
