Salta al contenuto principale
Acer Aspire AS3810TZ-4806 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire AS3810TZ-4806 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unlock the battery release by sliding it to the right.
  2. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire AS3810TZ-4806 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the release button and remove the battery.
  3. Acer Aspire AS3810TZ-4806 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Make sure your device is powered off and the battery is removed.
  4. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the three Phillips screws on the hard drive cover so the cover may be removed.
  5. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: passo 5, immagine 1 di 1
    • After the cover is removed, remove the hard drive from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 109
