Salta al contenuto principale
Acer Aspire 7741Z-4643 Wireless Card Replacement
Cosa ti serve
  1. Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: passo 1, immagine 1 di 2 Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: passo 1, immagine 2 di 2
    • Begin by unscrewing the four phillips #0 7.5mm screws on the plate on the underside. Remove the plate by lifting up.
  2. Acer Aspire 7741Z-4643 Wireless Card Replacement: passo 2, immagine 1 di 3 Acer Aspire 7741Z-4643 Wireless Card Replacement: passo 2, immagine 2 di 3 Acer Aspire 7741Z-4643 Wireless Card Replacement: passo 2, immagine 3 di 3
    • Unscrew the one phillips #0 4.0mm screw at the top of the card in order for it to be removed.
    • After the screw is removed, slide the card out. Remove connections to the terminals by pulling up on the connection carefully.
Conclusione
UC Davis, Team S11-G4, Lore Fall 2018 Membro di UC Davis, Team S11-G4, Lore Fall 2018
UCD-LORE-F18S11G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 489
