Salta al contenuto principale
Acer Aspire 7736Z-4809 RAM Replacement
Cosa ti serve
  1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  2. Acer Aspire 7736Z-4809 RAM Replacement: passo 2, immagine 1 di 3 Acer Aspire 7736Z-4809 RAM Replacement: passo 2, immagine 2 di 3 Acer Aspire 7736Z-4809 RAM Replacement: passo 2, immagine 3 di 3
    • Remove the back panel of the laptop.
  3. Acer Aspire 7736Z-4809 RAM Replacement: passo 3, immagine 1 di 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  4. Acer Aspire 7736Z-4809 RAM Replacement, RAM: passo 4, immagine 1 di 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: passo 4, immagine 2 di 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: passo 4, immagine 3 di 3
    • Release the tabs on the RAM by bending the tabs away from the RAM.
    • The RAM will rise upwards at an angle.
  5. Acer Aspire 7736Z-4809 RAM Replacement: passo 5, immagine 1 di 2 Acer Aspire 7736Z-4809 RAM Replacement: passo 5, immagine 2 di 2
    • Pull the RAM out of the slot.
    • If you are replacing both sticks of RAM, repeat the previous step for removing the RAM.
Conclusione
UC Davis, Team 2-4, Oliver Fall 2016 Membro di UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Membri
10 Guide realizzate
2 Commenti
“supports the DDR2 667MHz memory,240-pin soDIMM RAM “
It’s a laptop and what you are holding is a 200-pin soDIMM RAM module.
BaronDRS - Replica
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
1videopirate - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 608
