Salta al contenuto principale
Acer Aspire 7736Z-4809 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Acer Aspire 7736Z-4809 Repair Preparation: passo 1, immagine 1 di 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: passo 3, immagine 1 di 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: passo 3, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 4, immagine 1 di 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 4, immagine 2 di 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the 3.5mm Phillips #1 screw.
  7. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 7, immagine 1 di 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Slide the bracket towards you to release it from the frame.
  8. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 8, immagine 1 di 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 8, immagine 2 di 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 8, immagine 3 di 3
    • Use the black tab to pull the hard drive up and out of the laptop.
  9. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 9, immagine 1 di 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 9, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the four 3.5 Phillips #1 screws.
  10. Acer Aspire 7736Z-4809 Hard Drive Replacement: passo 10, immagine 1 di 1
    • Remove the hard drive from the bracket and install the new hard drive.
Conclusione
UC Davis, Team 2-4, Oliver Fall 2016 Membro di UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,088
