Salta al contenuto principale
Acer Aspire 7736Z-4809 Back Panel Removal
Cosa ti serve
  1. Acer Aspire 7736Z-4809 Back Panel Removal, Acer Aspire 7736Z-4809 Repair Preparation: passo 1, immagine 1 di 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Back Panel Removal: passo 2, immagine 1 di 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: passo 3, immagine 1 di 2 Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: passo 3, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Back Panel Removal: passo 4, immagine 1 di 3 Acer Aspire 7736Z-4809 Back Panel Removal: passo 4, immagine 2 di 3 Acer Aspire 7736Z-4809 Back Panel Removal: passo 4, immagine 3 di 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Back Panel Removal: passo 5, immagine 1 di 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
Conclusione
UC Davis, Team 2-4, Oliver Fall 2016 Membro di UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 525
