Introduzione
This guide will how you how to remove the power board under the power button on your Acer Aspire 6530-6522. You will need to do this if it becomes faulty or gets damaged.
Cosa ti serve
Make sure the device is unplugged and completely powered down.
Turn the device over.
Using the Phillips #1 screwdriver, remove the ten 7mm screws in the bottom of the device that are holding the top panel.
Turn the device over and open it.
Quasi finito!
Conclusione
