Salta al contenuto principale
Acer Aspire 6530-6522 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire 6530-6522 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire 6530-6522 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Keyboard Replacement: passo 2, immagine 1 di 2 Acer Aspire 6530-6522 Keyboard Replacement: passo 2, immagine 2 di 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Keyboard Replacement: passo 3, immagine 1 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 3, immagine 2 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 3, immagine 3 di 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Keyboard Replacement: passo 4, immagine 1 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 4, immagine 2 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 4, immagine 3 di 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 Acer Aspire 6530-6522 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the nine 7mm screws holding the top panel.
    • Flip device right side up and open it.
  6. Acer Aspire 6530-6522 Keyboard Replacement: passo 6, immagine 1 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 6, immagine 2 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 6, immagine 3 di 3
    • Lift the top panel up, rotating forward onto the keyboard.
    • Do not try to remove yet, cables are still attached.
  7. Acer Aspire 6530-6522 Keyboard Replacement: passo 7, immagine 1 di 2 Acer Aspire 6530-6522 Keyboard Replacement: passo 7, immagine 2 di 2
    • Lift the black latch on each connection securing the cables.
    • Pull the cable free.
  8. Acer Aspire 6530-6522 Keyboard Replacement: passo 8, immagine 1 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 8, immagine 2 di 3 Acer Aspire 6530-6522 Keyboard Replacement: passo 8, immagine 3 di 3
    • Lift the keyboard up by the center of the back. You may need a plastic tool such as the black plastic spudger to get under the edge.
    • Lift up, pulling the edges from under the top cover, and lay down on the front of the device.
    • Do not pull away, there is still a cable connecting the keyboard.
  9. Acer Aspire 6530-6522 Keyboard Replacement: passo 9, immagine 1 di 2 Acer Aspire 6530-6522 Keyboard Replacement: passo 9, immagine 2 di 2
    • Lift the black clasp holding the cable.
    • Remove the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 521
