Salta al contenuto principale
Acer Aspire 6530-6522 Battery Replacement
Cosa ti serve
  1. Acer Aspire 6530-6522 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire 6530-6522 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire 6530-6522 Battery Replacement: passo 2, immagine 2 di 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Battery Replacement: passo 3, immagine 1 di 3 Acer Aspire 6530-6522 Battery Replacement: passo 3, immagine 2 di 3 Acer Aspire 6530-6522 Battery Replacement: passo 3, immagine 3 di 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Battery Replacement: passo 4, immagine 1 di 3 Acer Aspire 6530-6522 Battery Replacement: passo 4, immagine 2 di 3 Acer Aspire 6530-6522 Battery Replacement: passo 4, immagine 3 di 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 208
