Salta al contenuto principale
Acer Aspire 5750-6677 Motherboard Replacement
Cosa ti serve
  1. Acer Aspire 5750-6677 Motherboard Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Motherboard Replacement: passo 2, immagine 1 di 1
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: passo 4, immagine 1 di 2 Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Motherboard Replacement: passo 5, immagine 1 di 2 Acer Aspire 5750-6677 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Motherboard Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull the tab and lift up to remove the hard drive.
  8. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Start by flipping the device over to expose the screws.
    • Remove ten screws with the Phillips #0 screwdriver.
  9. Acer Aspire 5750-6677 Motherboard Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the four screws found under the battery.
  10. Acer Aspire 5750-6677 Motherboard Replacement: passo 10, immagine 1 di 2 Acer Aspire 5750-6677 Motherboard Replacement: passo 10, immagine 2 di 2
    • Flip the laptop back around so the Acer logo is facing upwards.
    • Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
  11. Acer Aspire 5750-6677 Motherboard Replacement: passo 11, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove six screws.
    • Pull the top off of the keyboard to expose the motherboard.
  12. Acer Aspire 5750-6677 Motherboard Replacement: passo 12, immagine 1 di 3 Acer Aspire 5750-6677 Motherboard Replacement: passo 12, immagine 2 di 3 Acer Aspire 5750-6677 Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove the seven screws using the Phillips #0 screwdriver.
    • Detach any wires or cables that are attached to the motherboard.
    • Remove the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Dean Smith
Membro da: 11/01/19
222 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,058
