Introduzione
The keyboard on a laptop can often times be damaged easily from accidental water damage or stop functioning from over-use. The keyboard can be removed with the release of 6 tabs and by gently releasing an attached cable.
Cosa ti serve
Turn the laptop right-side up and open the lid.
Locate the 6 black plastic tabs on the top edge of the keyboard that are holding the keyboard in place.
Starting in one corner, use tweezers to push the tabs inward to release the keyboard and then use the tweezers to gently pry the keyboard up and away from the laptop.
Repeat this step to each of the 6 tabs along the top of the keyboard. Use your blue plastic opening tool to keep the released sections of the keyboard up.
Altre 5 persone hanno completato questa guida.
