Salta al contenuto principale
Acer Aspire 5749 Fan/HeatSink Replacement
Cosa ti serve
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, immagine 1 di 3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, immagine 2 di 3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, immagine 3 di 3
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, immagine 1 di 3 Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, immagine 2 di 3 Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, immagine 3 di 3
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, immagine 1 di 3 Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, immagine 2 di 3 Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, immagine 3 di 3
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
Conclusione
Altre 8 persone hanno completato questa guida.
5 Commenti
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - Replica
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - Replica
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - Replica
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 7,714
