Salta al contenuto principale
Acer Aspire 5742G Memory stick Replacement
Cosa ti serve
Panoramica Video
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: passo 1, immagine 1 di 1
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: passo 2, immagine 1 di 1
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: passo 3, immagine 1 di 2 Acer Aspire 5742G Memory stick Replacement: passo 3, immagine 2 di 2
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: passo 4, immagine 1 di 1
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: passo 5, immagine 1 di 1
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
Conclusione
Altre 2 persone hanno completato questa guida.
Kid fixers Membro di Kid fixers
Community
169 Membri
225 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 800
