Salta al contenuto principale
Acer Aspire 5742 Hard Drive Removal
Cosa ti serve
  1. Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, immagine 1 di 3 Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, immagine 2 di 3 Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, immagine 3 di 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, immagine 1 di 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, immagine 2 di 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, immagine 3 di 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: passo 3, immagine 1 di 3 Acer Aspire 5742 Hard Drive Removal: passo 3, immagine 2 di 3 Acer Aspire 5742 Hard Drive Removal: passo 3, immagine 3 di 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, immagine 1 di 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, immagine 2 di 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, immagine 3 di 3
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusione
Altre 16 persone hanno completato questa guida.
4 Commenti
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Replica
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Replica
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 82
Tutti i Tempi: 45,334
