Cosa ti serve
Use spudger to gently pry off open middle cover.
Then flip the middle cover over onto the keyboard.
Passo 7 Prepare Acer Aspire 5740-5780 for Disassembly
Attenzione: i passaggi 7-10 provengono da una guida contrassegnata come in corso.
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
Retrieve the WLAN antenna wire from underneath the keyboard.
Detach the LCD cable from the main board.
