Salta al contenuto principale
Acer Aspire 5534-1096 Battery Replacement
  1. Acer Aspire 5534-1096 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Disconnect laptop from electric source prior to any repair.
    • On the bottom side of the laptop, you will unlock the safety lock by sliding it towards the left.
  2. Acer Aspire 5534-1096 Battery Replacement: passo 2, immagine 1 di 1
    • Now, you'll hold this latch to the left. Everything is unlatched. The battery should feel free.
  3. Acer Aspire 5534-1096 Battery Replacement: passo 3, immagine 1 di 3 Acer Aspire 5534-1096 Battery Replacement: passo 3, immagine 2 di 3 Acer Aspire 5534-1096 Battery Replacement: passo 3, immagine 3 di 3
    • While continuing to hold the latch in the open position, use your other hand to push the battery away from the device to remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 317
