Salta al contenuto principale
Acer Aspire 5349-2592 RAM Replacement
Cosa ti serve
  1. Acer Aspire 5349-2592 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 RAM Replacement: passo 2, immagine 1 di 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 RAM Replacement: passo 3, immagine 1 di 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 RAM Replacement: passo 4, immagine 1 di 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 RAM Replacement, Back plate: passo 5, immagine 1 di 1
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 RAM Replacement: passo 6, immagine 1 di 1
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 RAM Replacement, RAM: passo 7, immagine 1 di 2 Acer Aspire 5349-2592 RAM Replacement, RAM: passo 7, immagine 2 di 2
    • Push the clips securing the RAM outwards.
    • The RAM stick will pop up and is safe to remove from the device. Repeat the same process for additional RAM sticks.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,130
