Salta al contenuto principale
Acer Aspire 5349-2592 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire 5349-2592 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Keyboard Replacement: passo 2, immagine 1 di 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Keyboard Replacement: passo 3, immagine 1 di 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Keyboard Replacement: passo 4, immagine 1 di 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Open the laptop and locate the top edge of the keyboard.
    • Use a flathead screwdriver to gently pry the keyboard upward and lift it out of the laptop.
  6. Acer Aspire 5349-2592 Keyboard Replacement: passo 6, immagine 1 di 1
    • Use a flathead screwdriver to gently lift the clamp upward and remove the cable.
  7. Acer Aspire 5349-2592 Keyboard Replacement: passo 7, immagine 1 di 1
    • The keyboard is now disconnected and can be safely removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,084
