Salta al contenuto principale
Acer Aspire 5334-2581 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 5334-2581 Hard Drive  Replacement, Battery: passo 1, immagine 1 di 1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Hard Drive  Replacement: passo 2, immagine 1 di 1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Hard Drive  Replacement: passo 3, immagine 1 di 1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Hard Drive  Replacement: passo 4, immagine 1 di 1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Hard Drive  Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the two screws that hold the hard drive cover.
    • Lift the cover up and set it aside.
  6. Acer Aspire 5334-2581 Hard Drive  Replacement: passo 6, immagine 1 di 1
    • Be very careful not to damage the hard drive when removing it because you might damage the data.
    • Slide the hard drive out of its seat.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-2, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 404
