Cosa ti serve
Now, locate the two screws that hold the back cover panel onto the laptop.
After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
Hello. Vous avez oublié de mentionner le démontage du disque dur (une vis) et le débranchement des fils des antennes wifi qui ne gênent pas pour vous lors du démontage de la carte mère.
Locate the tabs keeping the keyboard in place.
After you have removed all of the prerequisites its time to unscrew a few more screws. Flip your laptop over and first remove all the screw highlighted in red with the Phillips #00 screwdriver. These are 1/4" head diameter by 3/8" screw length screws.
Now remove the screws highlighted in orange with the Phillips #00 screwdriver. These are 5/32" head diameter by 5/32" screw length screws. Keep these separate from the other screws.
Hello. Il manque un rond rouge autour de la vis qu’on aperçoit sur la gauche, à peu près au milieu de la longueur des barettes mémoire. Celle-ci et celle du disque dur (oublié plus haut) bloquent le retrait du couvercle supérieur.
Flip the Laptop back over, and unscrew the 1/4" diameter head 7/32" length screws indicated in the picture.
Il manque un rond rouge sur la vis à droite du connecteur écran, bien qu’on voie qu’elle est enlevée sur la seconde image.
Here is a close-up of all of the connectors. Remember to use tweezers on the black part and carefully pull out both sides. Once it has been moved back slightly, pull the connector out just like the keyboard.
The third picture shows the connector to the speakers which can just be pulled straight out by tweezers.
Altre 13 persone hanno completato questa guida.
2 Commenti
I was 20 % started when I decided to find out if some one post on fan removal and lo and behold your post became,very useful, ,the rest was easy like sunday morning ,thanks guy for posting
Merci bonne courage
