Salta al contenuto principale
Acer Aspire 5251-1513 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 5251-1513 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire 5251-1513 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Hard Drive Replacement: passo 3, immagine 1 di 2 Acer Aspire 5251-1513 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Hard Drive Replacement: passo 4, immagine 1 di 2 Acer Aspire 5251-1513 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Hard Drive Replacement: passo 6, immagine 1 di 2 Acer Aspire 5251-1513 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 Hard Drive Replacement: passo 7, immagine 1 di 2 Acer Aspire 5251-1513 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Slide the hard drive to the left until it clicks and then pull it out completely.
  8. Acer Aspire 5251-1513 Hard Drive Replacement: passo 8, immagine 1 di 3 Acer Aspire 5251-1513 Hard Drive Replacement: passo 8, immagine 2 di 3 Acer Aspire 5251-1513 Hard Drive Replacement: passo 8, immagine 3 di 3
    • Unscrew the four 3.6 mm screws on either side of the casing with the Phillips #0 screwdriver.
    • Remove the hard drive out of its casing.
    • Be Gentle with the hard rive, only touch the edges.
Conclusione
Gicely Rodriguez
Membro da: 02/14/19
1.029 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G6, Leahy Spring 2019 Membro di USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 574
