Salta al contenuto principale
Acer Aspire 5100 RAM Replacement
Cosa ti serve
  1. Acer Aspire 5100 RAM Replacement, RAM: passo 1, immagine 1 di 2 Acer Aspire 5100 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: passo 2, immagine 1 di 3 Acer Aspire 5100 RAM Replacement: passo 2, immagine 2 di 3 Acer Aspire 5100 RAM Replacement: passo 2, immagine 3 di 3
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
Conclusione
Altre 7 persone hanno completato questa guida.
Brad Rollinson
Membro da: 09/29/10
1.113 Reputazione
7 Guide realizzate
Cal Poly, Team 14-39, Forte Fall 2010 Membro di Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membri
10 Guide realizzate
Un commento
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 16,278
