Salta al contenuto principale
Acer Aspire 5100 Hard Drive Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Acer Aspire 5100 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Acer Aspire 5100 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Start by locating the small panel directly to the right of the battery.
  3. Acer Aspire 5100 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the two screws securing the panel.
  4. Acer Aspire 5100 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Grip the right side of the hard drive and pull towards the right side of the computer
    • Remove the mounting bracket from the old hard drive.
    • Transfer the mounting bracket to the new hard drive and install the new drive.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
Un commento
didnot give good information for newly observed person
venki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,214
