Salta al contenuto principale
Acer Aspire 5 A515-56-347N RAM Replacement
Cosa ti serve
  1. Acer Aspire 5 A515-56-347N RAM Replacement, Bottom Cover: passo 1, immagine 1 di 2 Acer Aspire 5 A515-56-347N RAM Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Acer Aspire 5 A515-56-347N RAM Replacement: passo 2, immagine 1 di 3 Acer Aspire 5 A515-56-347N RAM Replacement: passo 2, immagine 2 di 3 Acer Aspire 5 A515-56-347N RAM Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Acer Aspire 5 A515-56-347N RAM Replacement, Disconnecting the Battery: passo 3, immagine 1 di 3 Acer Aspire 5 A515-56-347N RAM Replacement, Disconnecting the Battery: passo 3, immagine 2 di 3 Acer Aspire 5 A515-56-347N RAM Replacement, Disconnecting the Battery: passo 3, immagine 3 di 3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Acer Aspire 5 A515-56-347N RAM Replacement: passo 4, immagine 1 di 2 Acer Aspire 5 A515-56-347N RAM Replacement: passo 4, immagine 2 di 2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
  5. Acer Aspire 5 A515-56-347N RAM Replacement, RAM: passo 5, immagine 1 di 2 Acer Aspire 5 A515-56-347N RAM Replacement, RAM: passo 5, immagine 2 di 2
    • Holding the RAM chip by its sides, line it up with the notches in the RAM slot.
    • Gently push the RAM chip down until you hear the metal tabs on the sides click.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 43
Tutti i Tempi: 342
