Salta al contenuto principale
Acer Aspire 5 A515-54 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 5 A515-54 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn off and unplug your Acer Aspire 5 A515-54.
    • Flip it over so the backside is facing up.
  2. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 2, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 2, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove eleven 9 mm screws securing the back cover.
    • Use a prying tool to gently open the back cover of the laptop.
  3. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 3, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 3, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Be sure to ground yourself or wear an antistatic bracelet to avoid static discharge and damage to the motherboard.
    • Disconnect the battery by gently pulling out the connector.
  4. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 4, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 4, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Notice there is a mounting tray with a cable for the additional HDD. Remove the four 3 mm screws with a Phillips #0 screwdriver.
    • Take out the mounting tray and connector to prepare for the hard drive installation in the next step.
  5. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 5, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 5, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 5, immagine 3 di 3
    • Take the connector from previous step and connect it to the new hard drive.
    • Insert the drive into the mounting tray.
  6. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 6, immagine 1 di 2 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 6, immagine 2 di 2
    • There are 2 mm screws that come with the laptop box.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws to the mounting tray, which holds the HDD .
  7. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 7, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 7, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Slide the mounting bracket with the hard drive into the socket (with the cable facing towards the battery).
    • Use the Phillips #0 screwdriver to replace the 3 mm screws and hold the bracket in place.
  8. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 8, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 8, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 8, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the single screw attaching the wireless card to the motherboard.
    • Gently slide the wireless card out of the socket and set it aside in order to connect the hard drive to the motherboard.
  9. Acer Aspire 5 A515-54 Hard Drive Replacement: passo 9, immagine 1 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 9, immagine 2 di 3 Acer Aspire 5 A515-54 Hard Drive Replacement: passo 9, immagine 3 di 3
    • Gently insert the hard drive cable into the connector on the motherboard and lock it in place.
    • Slide the wireless card back into the socket and using the Phillips #0 screwdriver, secure with the single screw.
Conclusione
After replace and install the new hard drive to the laptop, you need to format the new drive and that's it. You have upgraded the hard drive of your laptop.
Altre 2 persone hanno completato questa guida.
Luan Tu
Membro da: 09/17/21
205 Reputazione
1 Guida realizzata
2 Commenti
I currently have a 256gb ssd in my Acer Aspire 5 A515-54. I would like to upgrade to a 1TB ssd and this guide is great but how can I transfer the data to the new ssd?
William Carcoba - Replica
Try using a hdd cloning software.
Fuzzy_Pickles -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 225
Tutti i Tempi: 8,241
