Salta al contenuto principale
Acer Aspire 4810TZ-4120 Fan Replacement
Cosa ti serve
  1. Acer Aspire 4810TZ-4120 Fan Replacement, Fan: passo 1, immagine 1 di 2 Acer Aspire 4810TZ-4120 Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Lay the acer upside down
    • Use your screwdriver to unscrew all 19 two 5mm Phillips screws from the case
    • After unscrewing all the screws, lift the case upwards and remove it
  2. Acer Aspire 4810TZ-4120 Fan Replacement: passo 2, immagine 1 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 2, immagine 2 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 2, immagine 3 di 3
    • Go on the side of the computer
    • Use the plastic opening tool and press it in between the upper case and lover case
    • When the plastic tool is in between the cases, start going around the computer until both case are officially not connected
  3. Acer Aspire 4810TZ-4120 Fan Replacement: passo 3, immagine 1 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 3, immagine 2 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 3, immagine 3 di 3
    • Get a pair of tweezers
    • Start to detach the wires that are connected to the computer
    • Get a screwdriver and unscrew the screws that are circled in the picture
  4. Acer Aspire 4810TZ-4120 Fan Replacement: passo 4, immagine 1 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 4, immagine 2 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 4, immagine 3 di 3
    • Repeat Step 3 for detaching the rest of the tape
    • Disconnect all wires from the boards
  5. Acer Aspire 4810TZ-4120 Fan Replacement: passo 5, immagine 1 di 2 Acer Aspire 4810TZ-4120 Fan Replacement: passo 5, immagine 2 di 2
    • Lift up the upper case
    • Disconnect the power supply wiring (the black wire)
  6. Acer Aspire 4810TZ-4120 Fan Replacement: passo 6, immagine 1 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 6, immagine 2 di 3 Acer Aspire 4810TZ-4120 Fan Replacement: passo 6, immagine 3 di 3
    • Remove the three screws
    • Pull the boards upward
    • Flip the boards upside down
    • The screws and the board were removed so that the holes could be better shown
  7. Acer Aspire 4810TZ-4120 Fan Replacement: passo 7, immagine 1 di 2 Acer Aspire 4810TZ-4120 Fan Replacement: passo 7, immagine 2 di 2
    • Remove the four (4) screws that are holding the CPU's cover on
  8. Acer Aspire 4810TZ-4120 Fan Replacement: passo 8, immagine 1 di 2 Acer Aspire 4810TZ-4120 Fan Replacement: passo 8, immagine 2 di 2
    • Gently detached the wire that is connected to the computer
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 88
